PreviousNextJavaScript must be enabled to correctly display this content
Configuring the server-capabilities-table
A
server-capabilities-table is a multi-instance element that allows the user to name a
servers-capability object and apply it to a
registrar. A
servers-capability object is a
server-capabilities-table sub-element that includes a
capability and multiple server names, which support that capability.
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the session router path.
ORACLE(configure)# session-router
Type
server-capabilities-table and press Enter to access the path.
Enter a contiguous string to the
name field. This name is the reference used in the registrar configuration to specify the use of this server capabilities table.
Type
servers-capability and press Enter to access the path.
Enter a number to specify the capability
capability. Valid entries range from 0 to 999999999.
Enter the names of the servers that belong to this
server-name-list. Name format is the same as that used within the registrar's
home-server-route field. The format is the URI (containing FQDN or IP address) used to identify a server to the HSS. Each entry in the list is enclosed with quotes and separated by comma.
Type
done and
exit twice to complete configuration of this
server-capabilities-table configuration element.
