Originating request - Registered User
When the Oracle Communications Core Session Manager receives an Initial request, it is validated as an originating request from or on behalf of a registered user when the following conditions are met:
- When the
ignore-psu-sesscase option is not set:
- The request is a dialog creating request or a standalone request.
- There is no "odi" parameter in the top route of the request.
- The regstate and sescase parameters of the P-served-user indicate for this to be treated as originating request for a registered user.
- When the
ignore-psu-sesscase option is set:
- There is an "orig" parameter in the top route of the request.
- The served user is registered
