Primary and Secondary ENUM Configuration
For the purpose of redundancy, the Oracle Communications Core Session Manager allows you to configure these number lookups to use a backup resource in case the lookup at the primary fails. Such scenarios include losing contact with the primary ENUM/LRT server config (query time-out) and the entry is not found at the primary (LRT or ENUM).
To apply primary and secondary number lookup resources to a sip-registrar:
