Parameters
name—Configured name of this sip registrar.
- Default: empty
state—Running status of this policy-director-group.
- Default: enabled
- Values: enabled | disabled
domains—List of registration domains that this Oracle Communications Core Session Manager is responsible for. * means all domains. These domains are compared for an exact match with the domain in the request-uri of the REGISTER message. the wildcard ‘*’ can also be entered as part of this parameter. This is entered as the domains separated by a space in quotes. No quotes required if only one domain is being configured. "+" and "-"are used to add to subtract from the list.
- Default: empty
subscriber-database-method—Protocol used to connect to User Subscriber Database server.
- Default: CX
- Values: CX | DDNS | local
subscriber-database-config—The configuration element that defines the server used for retrieving user subscriber data. For Cx deployments it is a home-subscriber-server name. For ENUM deployments it is an enum-config name.
- Default: empty
authentication-profile—Name of the sip-authentication-profile configuration used to retrieve authentication data when an endpoint is not authenticated.
- Default: empty
home-server-route—The value inserted into the Server Name AVP in an MAR message. This should be entered as a SIP URI as per 3gpp TS 24229 & RFC 3261. The host can be FQDN or IPv4 address, and the port portion should be in the 1025 - 65535 range. Examples: SIP:12.12.12.12:5060
- Default: empty
third-party-registrars—The third-party-regs configuration element names where third party REGISTER messages will be forwarded to.
- Default: empty
routing-precedence—Indicates whether INVITE routing lookup should use the user database (via the registrar configuration element) or perform local policy lookup immediately.
- Default: registrar
- Values: registrar | local-policy
egress-realm-id—Indicates the default egress/core realm for SIP messaging.
- Default: empty
location-update-interval—Sets the maximum period in minutes in which the core-side user subscriber database is refreshed, per user.
- Default: 1440
- Values: 0-999999999
ifc-profile—References the ifc-profile configuration element’s name that is applied to this sip-registrar.
max-contacts-per-aor—Limit to the number of contacts allowed for a given AOR.
- Default: 0 (disabled)
- Values: 1 - 256
ims-restoration—Enables the device to perform standards-based IMS restoration procedures with a compliant HSS deployment.
- Default: disabled
