release-user
This command releases registered users from the Oracle Communications Core Session Manager on which the command is issued. The SLRM re-balances the deployment by registering these users on another Oracle Communications Core Session Manager upon the next registration cycle. This command only releases users up to the count specified. The process includes a time out at 30 minutes, after which the release-user command stops releasing users regardless of whether it has reached the configured user count. A user is only released if it is not in an active session.
If an HA switchover occurs before the release-users command has finished, the process does not continue to release users. If desired, the user can re-issue the command on the backup system after the switchover is complete.Parameter
- <count>
- Specify the number of users that the system must release. The system marks this number of users for release, and begins to remove users until it reaches this number.
- stop
- The system removes all users from the list of users currently marked for release.
- status
- The system displays a list of all users marked for release from each cluster.
Path
release-user is an command available to superusers.
Release
First appearance: S-Cz7.1.5
