Caveats and Limitations
The following information lists and describes the caveats and limitations for this release. Oracle updates this Release Notes document to distribute issue status changes. Check the latest revisions of this document to stay informed about these issues.
OCCSM Caveats
This section list caveats related to Version S-CZ8.2.5 of the Oracle Communications Core Session Manager.
- Do not load configurations from sibling products, the Oracle SBC for example, on the Oracle Communications Core Session Manager. Those configurations are incompatible with the Oracle Communications Core Session Manager, causing incorrect operation. Users should configure the Oracle Communications Core Session Manager from scratch or use another valid Oracle Communications Core Session Manager configuration.
- Configuration elements
specific to the SLRM, including lb-interface are not compatible with
Session Manager configuration elements. The
set-component-type
command provides a warning indicating that the user must delete any prior
configuration and create the new component type configuration from scratch to
avoid potential configuration conflicts. Note the sample output below.
SCZ715_64# set-component-type core-load-balancer WARNING: Changing component type is service impacting. ******************************************************** Ensure that you follow these steps if you choose to change the component type: 1. Issue the delete-config command. 2. Reboot. ******************************************************** Continue with the change [y/n]?:
- Multi-stage routing does not work for S-CSCF routing functions.
- The Oracle Communications Core Session Manager does not support 'netboot' when operating on the Oracle VM platform. The user must, instead, upload new images to the Oracle Communications Core Session Manager and boot from them locally.
By default, storage is not persistent across a reboot of a Oracle Communications Core Session Manager virtual machine. You must create persistent storage space for log and dump file data.
- Issue - Generic virtual machine installation documentation may not include the requirement to run the command format hard-disk during virtual machine installation.
- Resolution - Run the command format hard-disk to create a persistent partition for your /opt directory, within which you can store data needed after a reboot. Perform this procedure the FIRST time you start your Oracle Communications Core Session Manager.
- The
OCCSM accepts only the
first message received from an application server in response to messages from
the
OCCSM that included an
ODI. If it receives subsequent messages from that application server, the
OCCSM drops the reused
ODI and processes the message as if they were received without an ODI.
- Resolution - Do not configure an AS to fork responses to the OCCSM that include an ODI originally provided by the OCCSM.
- Geo-redundancy is currently not supported by the OCCSM.
Caveats Inherited from the S-CZ8.2.0 SBC
Refer to the Caveats in the S-CZ8.2.0 OCSBC Release Notes to complete your review of issues in this release. Issues withinin the OCSBC, especially including applicable VNF platform and applicable application issues apply across the S-CZ8.2.x product versions, including the OCCSM.
