Oracle Communications System Management MIB (ap-corelb.mib)
The following table describes the SLRM-related SNMP GET query names for the Oracle Core Load Balancer MIB (ap-corelb.mib).
| SNMP GET Query Name | Object Identifier Name: Number | Description |
| Object Identifier Name: apCoreLBModule (1.3.6.1.4.1.9148.3.19) | ||
| Object Identifier Name: apCoreLBMIBObjects (1.3.6.1.4.1.9148.3.19.1) | ||
| Object Identifier Name: apCoreLBMIBGeneralObjects (1.3.6.1.4.1.9148.3.19.1.1) | ||
| apCoreLBMemberAddress | 1.3.6.1.4.1.9148.3.19.1.1.1 | This is the IP address of the CSM registered with the SLRM. |
| apCoreLBMemberAddressType | 1.3.6.1.4.1.9148.3.19.1.1.2 | This is the protocol version of the IP address of the CSM registered with the SLRM. |
| apCoreLBMemberPort | 1.3.6.1.4.1.9148.3.19.1.1.3 | This is the IP port of the CSM registered with the SLRM. |
| apCoreLBMemberId | 1.3.6.1.4.1.9148.3.19.1.1.4 | The cluster Id of the Core LB member. |
| apCoreLBReasonCode | 1.3.6.1.4.1.9148.3.19.1.1.5 | The reason for the core member failure. Values include service assoc terminated (0), service assoc timeout (1) and connection down (2). |
