Image Files and Boot Files
This software version, when deployed on virtual platforms, autodetects the hypervisor platform and sets up as the OCCSM. You can later configure the deployment as an Oracle Communications Session Load Balancer and Route Manager (OCSLRM) using the set component command.
For Virtual Machines
This S-CZ8.2.5 release includes distributions suited for deployment over hypervisors. Download packages contain virtual machine templates for a range of virtual architectures. Use the following distributions to the Oracle Communications Core Session Manager (OCCSM) as a virtual machine:nnSCZ825-img-vm_ovm.ova—Open Virtualization Archive (.ova) distribution of the OCCSM VNF for Oracle (XEN) virtual machines.nnSCZ825-img-vm_kvm.tgz—Compressed image file including OCCSM VNF for KVM virtual machines.nnSCZ825-img-vm_vmware.ova—Open Virtualization Archive (.ova) distribution of the OCCSM VNF for ESXi virtual machines.nnSCZ825_HOT.tar.gz—The Heat Orchestration Templates used with OpenStack.
The Oracle (XEN) Virtual Machine, KVM, and ESXi packages include:
- Product software—Bootable image of the product allowing startup and operation as a virtual machine. This disk image is in either the vmdk or qcow2 format.
usbc.ovf—XML descriptor information containing metadata for the overall package, including identification, and default virtual machine resource requirements. The .ovf file format is specific to the supported hypervisor.legal.txt—Licensing information, including the Oracle End-User license agreement (EULA) terms covering the use of this software, and third-party license notifications.
