IMS-AKA Change Client Port Configuration
An IMS-AKA profile establishes the client and server ports to be protected, and it defines lists of encryption and authentication algorithms the profile supports. You can configure multiple IMS-AKA profiles, which are uniquely identified by their names.
You apply an IMS-AKA profile to a SIP port configuration using the name.
To configure an IMS-AKA profile:
From Superuser mode, use the following command sequence to
navigate to ims-aka-profile configuration mode.
ORACLE# configure terminal ORACLE(configure)# security ORACLE(security)# ims-aka-profile ORACLE(ims-aka-profile)#
- name—Enter the name you want to give this IMS-AKA profile. This is the value you will use to apply the profile to a SIP port configuration. This parameter is required, and it has no default value.
protected-server-port—Enter the port number
of the protected server port, which is the port on which the Oracle Communications Unified
Session Manager
receives protected messages. The protected server port should not overlap with
the port range defined in the steering ports configuration using the same IP
address and the SIP interface. If there is overlap, the NAT table entry for the
steering port used in a call will prevent SIP messages from reaching the
system’s host processor.
This parameter defaults to 0, which disables the function associated with the parameter. The valid range for values is 1025 to 65535.
start-protected-client-port
(protected-client-port
in Release S-CX6.3.3M2 and earlier releases)—Enter the start value
for the pool of port numbers available following a successful
re-authentication. Like the protected server port, the protected client port
pool should not overlap with the port range defined in the steering ports
configuration using the same IP address and the SIP interface. If there is
overlap, the NAT table entry for the steering port used in a call will prevent
SIP messages from reaching the system’s host processor.
Any existing configuration for protected-client-port will be mapped to both start-protected-client-port and end-protected-client-port parameter values.
end-protected-client-port—Enter the end
value for the pool of port numbers available following a successful
re-authentication. Ensure that this value is greater than the value assigned to
start-protected-client-port. Note that the
maximum supported pool contains 5 entries. Like the protected server port, the
protected client port pool should not overlap with the port range defined in
the steering ports configuration using the same IP address and the SIP
interface. If there is overlap, the NAT table entry for the steering port used
in a call will prevent SIP messages from reaching the system’s host processor.
encr-alg-list—Enter the list of encryption
algorithms. You enter more than one value by separating the algorithms by
<Spaces> and enclosing all values in quotations marks:
This parameter defaults to the following three values: aes-cbc, des-ede3-cbc, and null.
auth-alg-list—Enter the list of
authentication algorithms. You enter more than one value by separating the
algorithms by <Spaces> and enclosing all values in quotations marks:
This parameter defaults to hmac-sha-1-96.
