PreviousNextJavaScript must be enabled to correctly display this content
IFC Evaluation
IFCs are evaluated as described in 3GPP TS 29.228. The Oracle Communications Unified
Session Manager supports all tags found in the 3GPP initial filter criteria specifications. An IFC is evaluated until its end, after which the call flow continues as expected.
