Parameters
state—Running status of this third party registration configuration element.
- Default: enabled
- Values: enabled | disabled
name—Configured name of this third party registration configuration element.
- Default: none
registrar-host—hostname of the configured session agent that will be third party server. This value is also used in the request-uri that is sent to the third party server.
- Default: none
from-user—The user part of the From URI in the REGISTER Request that is sent to the third party server in the REGISTER message. When this parameter is blank the user part of the From header from the incoming REGISTER Request will be used.
- Default: none
from-host—The host part of the From URI in the REGISTER Request that is sent the third party server in the REGISTER message. When this parameter is blank the Oracle Communications Unified Session Manager uses the egress hostname/ IP address as the host.
- Default: none
- Values: Format this the same as the "registrar-host" in sip-config.
retry-interval—number of seconds the Oracle Communications Unified Session Manager waits before retrying a 3rd Party Registration server after a failed registration.
- Default: 32
- Values: 0 - 3600
