CLF Response Failure
If there is no location string in a CLF’s repsone or the CLF rejects the call, the Oracle Communications Unified Session Manager uses the default location string parameter from the ingress SIP interface to populate the PANI header. The emergency call proceeds normally using this location string’s information for emergency LRT lookups.
