Configuring SIP Interface with reg-via-key and reg-via-match
If you do not want the use the call scenario associated with the SIP interface options in the New Behavior section, you do not need to make any change to your configuration.
If you want your call scenarios to resemble the one associated with the SIP interface options in the New Behavior section, then you need to configure reg-via-key and reg-via-match options on the SIP interface facing the UE.
To configure a SIP interface with the reg-via-key and reg-via-match options:
