Parameters
name—Configured name of this sip-authentication profile.
methods—List of SIP methods that prompt authentication. This is entered as the methods separated by a space in quotes. No quotes required if only one method is being configured. "+" and "-"are used to add to subtract from the list.
- Default: empty
anonymous-methods—List of SIP methods that prompt authentication when received from anonymous sources. This is entered as the methods separated by a space in quotes. No quotes required if only one method is being configured. "+" and "-" are used to add or subtract from the list.
- Default: empty
digest-realm—The value inserted into the digest-realm parameter in an authentication challenge header as sent to UA. (not used for Cx deployments)
- Default: empty
credential-retrieval-method—Protocol used to connect to the server providing authentication data.
- Default: ENUM-TXT
- Values: ENUM-TXT | CX
credential-retrieval-config—The home-subscriber-server name used for retrieving authentication data.
- Default: empty
