Monitoring
The ACLI show sipd endpoint-ip command is updated to show the IMS-AKA parameters corresponding to each endpoint. The display shows the algorithms used, the ports used, and the security parameter indexes (SPIs) used.
In addition, the show sa stats command now shows the security associations information for IMS-AKA.
