PreviousNextJavaScript must be enabled to correctly display this content
Applying an IMS-AKA Profile to a SIP Port
The final step in setting up IMS-AKA support is to apply an IMS-AKA profile to a SIP port. Enter the
name value from the IMS-AKA profile you want to apply in the SIP port’s
ims-aka-profile parameter.
To apply an IMS-AKA profile to a SIP port:
In Superuser mode, type
configure terminal and press Enter.
