PreviousNextJavaScript must be enabled to correctly display this content
Configuring Support for DDNS Server Caching
Use the procedure below to enable the
Oracle Communications Unified
Session Manager to cache and manage DDNS servers for the purpose of efficiently forwarding ENUM queries to the servers responsible for the DNS zones identified in applicable SIP requests.
From superuser mode, use the following command sequence to access enum-config configuration mode.
