Refreshing SiFC and DiFC Files
Given the nature of local file usage, an ACLI command is available to allow the user to refresh SiFC and DiFC contexts in memory after the user has saved changes to the SiFC and DiFC files. Run the following command to deploy these changes:
ORACLE# refresh ifc <ifc-profile name>
Note also that the Oracle Communications Unified Session Manager validates the SiFC and DiFC files whenever you Activate your configuration.
