TLS Session Setup During Registration
This call flow depicts a TLS session setup during the registration procedure. Only relevant header fields are noted.
(1) REGISTER
Proxy-Require:sec-agree Security-Client: ipsec-3gpp;alg=hmac-md5-96;ealg=aes-cbc;prot=esp;mod=trans;spi-c=8765423;port-c=7524;spi-s=1234563;port-s=1358, ipsec-3gpp;alg= hmac-sha-1-96;ealg=aes-cbc;prot=esp;mod=trans;spi-c=8765423;port-c=7524;spi-s=1234563;port-s=1358, tls
(2) REGISTER
Authorization: Digest uri="sip:ims.mnc007.mcc262.3gppnetwork.org",username="262073900320132@ims.mnc007.mcc262.3gppnetwork.org",response="",realm="ims.mnc007.mcc262.3gppnetwork.org",nonce="" (No integrity-protected field will be present if TLS is selected as the security mechanism)
(3) 401
Security-Server: tls
(4) REGISTER
Proxy-Require: sec-agree Security-Verify: tls
(5) REGISTER
Authorization: Digest username="262073900320132@ims.mnc007.mcc262.3gppnetwork.org",realm="imstest1.telefonica.de",uri="sip:ims.mnc007.mcc262.3gppnetwork.org",qop=auth,nonce="Ms8l2xeF3l4lb0VO8fK3KFMSKLv1sQAATdN2NpFUCgU=",nc=00000001,cnonce="3063397945",algorithm=AKAv1-MD5,response="3779ff40a057f999a2f8288bbfafc10d", integrity-protected=tls-pending
TLS Session Setup Prior to Registration
This call flow depicts a TLS session setup prior to the registration procedure.
(1) REGISTER
(No Security-Client or Proxy-Require header present)
(2) REGISTER
Authorization: Digest uri="sip:ims.mnc007.mcc262.3gppnetwork.org",username="262073900320132@ims.mnc007.mcc262.3gppnetwork.org",response="",realm="ims.mnc007.mcc262.3gppnetwork.org",nonce="" (No integrity-protected field will be present)
(3) 401
(No Security-Server header present)
(4) REGISTER
(No Security-Client, or Security-Verify or Proxy-Require header present)
(5) REGISTER
Regardless of TLS Session setup procedure, if the newly added configurable item sec-agree feature is enabled, any messages on unprotected port will be rejected except REGISTER messages or messages related to emergency services.
For refresh registration, if the Sec_Agree occurred during Registration, it verifies for the presence or change of Security-Client & Security-Verify headers, if they differ it will be rejected with 4xx response and also Authorization header fields are verified irrespective of the above methods and if they differ with previous association it will be rejected with 403 (Forbidden) response. Also when the refresh REGISTER is being forward to the core, it will set the integrity-protected field to "tls-yes".
