2629 - IR.92 Compliance via SIP 380 Response
This feature furthers the Oracle Communications Unified Session Manager’s compliance with GSMA's Voice over LTE specification (IR.92) to redirect VoLTE originated emergency calls to a circuit switched network.
When the Oracle Communications Unified Session Manager receives an emergency call, which it can not complete, it returns a 380 (Alternative Service) response to the sender. Some examples of when the Oracle Communications Unified Session Manager can not forward such an emergency call are:
- The Next-hop does not exist to route the call via NMC means
- The NSEP calls are rejected due to the Oracle Communications Unified Session Manager hitting a load limit
- The NSEP calls are rejected due to the target session agent exceeding constraints
- The NMC treatment for the call is set to Reject
