Third Party Registration for an Implicit Registration Set
When using iFCs, the Oracle Communications Unified Session Manager performs third party registrations based on the iFC downloaded for each PUID. By default, the Oracle Communications Unified Session Manager performs third party registration for the service profiles of all PUID's in a user's implicit registration set. This is compliant with 3GPP specifications. The system includes any shared or default iFCs that apply to each PUID during this process. The system performs this function when it receives user-initiated de-registrations, but not when it receives RTRs. If desired, the user can configure the Oracle Communications Unified Session Manager to perform third party registration for only the REGISTERED PUID in the registration using a sip-registrar option.
The Oracle Communications Unified Session Manager does not attempt third party registration for any barred, tel or wildcard PUIDs.The user can verify all third party registrations using the show registration sipd by-user [user] detailed command. Example output is shown below.
ORACLE# show registration sipd by-user 234 detailed
Registration Cache (Detailed View) Wed Sep 16 2015 10:57:44
User: sip:234@acme-ims.com
Registered at: 2015-09-16-10:57:40 Surrogate User: false
Emergency Registration? No
ContactsPerAor Rejects 0
ContactsPerAor OverWrites 0
Contact Information:
Contact:
Valid: true
Challenged: false
Last Registered at: 2015-09-16-10:57:40
Expire: 3596
Local expire: 296
Half: 1796
Registrar IP: 0.0.0.0
Transport: UDP
Secure: false
Local IP: 192.168.53.99:5060
User Agent Info:
Contact: sip:234@192.168.53.181:5060
Realm: core
IP: 192.168.53.181:5060
SD Info:
Contact: sip:234-tbcktcgo177fc@192.168.53.99:5060
Call-ID: 1-5853@192.168.53.181
Path: <sip:234@192.168.53.181:5060;lr;p-acme-serving>
Associated URI(s):
URI: sip:234@acme-ims.com
Status: Non-Barred
Filter Criteria:
Priority: 0
Filter: ((method == REGISTER)) or
((method == INVITE))
Application Server: sip:172.16.17.10:5060
URI: sip:1@acme-ims.com
Status: Non-Barred
Filter Criteria:
Priority: 0
Priority: 1
Filter: ((method == INVITE)) or
Application Server: sip:172.16.53.181:5065
URI: tel:135
Status: Barred
Filter Criteria:
Priority: 0
Priority: 1
Application Server: sip:172.16.53.181:5095
Third Party Registration(s):
Third Party Registration Host: 172.16.17.10
Registration State: REGISTERED
Last Registered at: Never
Third Party Registration Host: 172.16.53.181
The user can check for third party registrations errors using the show sipd third-party-reg all command. Example output is shown below.
ORACLE# show sipd third-party-reg all
3rd Party Registrar SA State Requests 200OK Timeouts Errors
(D)111.11.17.10 INSV 1 1 0 0
(D)111.11.53.181 INSV 1 1 0 0
The user can disable the default behavior and perform third party registration only for the PUID in the REGISTER by configuration. Disabling this behavior can improve system performance by preventing the system from having to walk through large PUID sets for large numbers of ASs. The ACLI syntax for disabling this functionality using the disable-thirdPartyReg-for-implicit-puid setting follows.
ORACLE(sip-registrar)#options +disable-thirdPartyReg-for-implicit-puid
Prior to this version, the Oracle Communications Unified Session Manager's default behavior was the same as if the disable-thirdPartyReg-for-implicit-puid option was set in the SIP registrar. Users upgrading to this version of the Oracle Communications Unified Session Manager must set the disable-thirdPartyReg-for-implicit-puid option to retain the previous behavior.
