IR.94 Loss Of Voice Bearer Configuration Use the following procedure to enable IR.94 compliance. Access the ext-policy-server configuration element. ORACLE# configure terminal ORACLE(configure)# media-manager ORACLE(media-manager)# ext-policy-server ORACLE(ext-policy-server)# Select the ext-policy-server object to edit. ORACLE(ext-policy-server)# select <name>:1: name=extpol1 selection: 1 ORACLE(ext-policy-server)# Use options terminate-on-voice-bearer-release to enable I.94 compliance. ACMEPACKET(ext-policy-server)# options +terminate-on-voice-bearer-release+ ACMEPACKET(ext-policy-server)# Type done to save your configuration.
