External Bandwidth Management
Is you are using the Oracle Communications Unified Session Manager's external bandwidth management for eSRVCC calls, note these considerations:
- At the time of handover and if the new handover realm has the same external policy server configured as the initial SIP session, the Rx will continue seamlessly with the same DIAMETER session identifier directed toward the policy server. From the perspective of the policy server, the same session is simply continuing.
- At the time of handover and if the new handover realm does not have an external policy server configured, policy server services will stop.
