LST Table
To configure the Oracle Communications Unified Session Manager to use an LST:
In Superuser mode, type configure terminal and press Enter.
ORACLE# configure terminal
Type session-router and press Enter to access the session router path.
ORACLE(configure)# session-router
Type local-subscriber-table and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# local-subscriber-table ORACLE(local-subscriber-table)#
You may now begin configuring the local subscriber table configuration element.
- name—Enter the name of this local subscriber table configuration element that will be referenced from a SIP registrar configuration element.
- filename—Enter the filename that describes this LST XML file. If no path is given, the Oracle Communications Unified Session Manager looks in the /code/lst directory. You may provide a complete path if the file is located elsewhere.
- secret—Enter the PSK used in encryption and decryption of the passwords in the XML file. Once saved, this value is not echoed back to the screen in plaintext format. See LST Subscriber Hash and Encryption.
- Type done when finished.
