SIP Feature Capabilities
The ATCF can announce a feature capability in a message by transporting the information in the Feature-Caps header, which is supported by the OCUSM.
The behavior of the two anchoring points, ATCF and ATGW, is defined by 3GPP in Release 12 of Technical Specification TS 24.237. Oracle Communications developed these functional entities based on the initial version of TS 24.237 Release 10, and has added the sip-feature-caps configuration element to align with Release 12.
When the state is enabled, the OCUSM includes the Feature-Caps header in applicable SIP messages. The information in the header is dependent on sip-feature-caps configuration.
- The g.3gpp.mid-call capability indicator.
- The g.3gpp.atcf-path parameter with a value set to the ATCF URI for terminating requests
- The g.3gpp.atcf parameter with a value of the configured atcf-stn-sr in sip-config
- The g.3gpp.atcf-mgmt-uri parameter with a value of the configured atcf-psi-dn in sip-config
Finally, when state is enabled, atcf-management-uri is not disabled, and atcf-alerting is enabled, the OCUSM adds the Feature-Caps header with the above and also adds the g.3gpp.srvcc-alerting capability indicator. Similarly, the OCUSM adds the g.3gpp.srvcc-pre-alerting capability indicator when atcf-pre-alerting is enabled.
