SIP Registrar
To configure a SIP registrar configuration element for message routing:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the session router path.
ORACLE(configure)# session-router
Type
sip-registrar and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-registrar ORACLE(sip-registrar)#
- Type select and choose the number of the pre-configured sip interface you want to configure.
- routing-precedence— Set this to either registrar or local-policy depending on your deployment.
- egress-realm-id—Enter the default egress realm for Oracle Communications Unified Session Manager messaging.
- Type done when finished.
