Initial Registration
When an endpoint registers, the Oracle Communications Unified Session Manager creates and sends an AAR message to a PCRF which includes the following information:
<AA-Request>::= < Diameter Header: 265, REQ, PXY >
| AVP | AVP Contents |
| Session-ID | OriginHost;0;0;<Key to Registration
Cache>
Key is usually the endpoint’s AoR. |
| Auth-Application-ID | Application-ID of Rx (16777236) |
| Origin-Host | <ext-policy-server_name>.<ext-policy-realm>.<domain-name-suffix> |
| Origin-Realm | <ext-policy-realm>.<domain-name-suffix> |
| Destination-Realm | <IP Address of endpoint>@<destination realm of this AAR> |
| Framed-IP-Address AVP - v4 address
Framed-IPv6-Prefix AVP - v6 address |
Layer 3 Endpoint-IP-address
v4 - Framed-IP-Addressor v6 - Framed-IPv6-Prefix |
| Media-Component | Grouped AVP description follows |
Media-Component-Description AVP ::= < AVP Header: 517 >
| Media-Component-Number | 0 |
| Media-Sub-Component | Grouped AVP description follows |
Media-Sub-Component ::= < AVP Header: 519 >
| Flow-Number | 1 |
| Flow-Description | Permit in <ip> from <Endpoint
IP:Port> to <OCUSM Sip Interface
IP:Port>
Permit out <ip> from <OCUSM SIP Interface IP:Port> to <Endpoint IP:Port> Where <ip> is (UDP: 17, TCP: 6) if wildcard-trans-protocol = disabled. |
| Flow-Status | Set to: ENABLED (2) |
| Flow-Usage | Set to: AF_SIGNALLING (2) |
| AF-Signalling-Protocol | Set to: SIP (1) |
