Wildcard PUI Introduction
The Oracle Communications Unified Session Manager supports wildcard Public User Identities (PUI). This capability is most often used to streamline processing of REGISTER and INVITE messages between a PBX and an IMS core.
The HSS (Home Subscriber Server, an IMS network-wide database) is pre-provisioned with the extension numbers associated with the PBX’s base telephone number. When the PBX registers its own base telephone number with the Oracle Communications Unified Session Manager, that server downloads a wildcarded PUI -- a regular expression that describes all extension numbers associated with the registering PBX.
The Oracle Communications Unified Session Manager constructs a registration cache entry to implicitly treat subsequent INVITEs from PBXs extensions that match the wildcard as registered endpoints.
A wildcarded PUI consists of a delimited regular expression located either in the user info portion of the SIP URI or in the telephone-subscriber portion of the Tel URI. The regular expression takes the form of an Extended Regular Expressions (ERE) as defined in chapter 9 of The Single UNIX Specification (IEEE 1003.1-2004 Part 1). The exclamation mark (!) serves as the delimiter.
For example, the following PUIs will match to the wildcard ERE "sip:chatlist!.*!@example.com".
sip:chatlist1@example.com sip:chatlist2@example.com sip:chatlist42@example.com sip:chatlistAbC@example.com sip:chatlist!1@example.com
