IMS Support for Private Header Extensions for 3GPP
As part of its RFC 3455 support, the Oracle Communications Unified Session Manager supports the following headers in its IMS implementation:
- P-Associated-URI
- P-Asserted-Identity
- P-Called-Party-ID
- P-Visited-Network-ID
The procedure to enable IMS access-side support is explained in the access interface configuration section. Any additional configuration required for specific header support is provided below.
