P-Asserted-Identity Header Configuration
This section explains how to configure the P-Asserted-Identity header for a session agent using the ACLI or Oracle Communications Session Delivery Manager.
P-Asserted-Identity header handling is enabled with the ims-access command on the SIP Interface, as described in the previous section. A P-Asserted-Identity header can be manually configured for a session agent if the automatic logic, explained earlier in this section, fails.
To configure the P-Asserted-Identity header for a session agent:
