Parameters
name—A given name for this local subscriber table element. This name is referenced from the sip-registrar configuration element when the credential-retrieval-method is set to local.
filename—The filename of local subscriber table that this element references. If no path is provided, the default location is /code/lst.
secret—PSK used for encrypted passwords. This value is not echoed back to the screen upon viewing the configuration element.
