Unreachability Determination
There are four ways that the Oracle Communications Unified Session Manager determines endpoint is not reachable:
- No CRLF message is returned to the Oracle Communications Unified Session Manager within the expected time frame: this is based on the Oracle USM’s RFC5626 support.
- No TCP Keepalive is returned to the Oracle Communications Unified Session Manager within the expected timeframe. This is based on configuring the network parameter configuration element per application interface.
- The endpoint explicitly terminates its transport-layer connection to the Oracle Communications Unified Session Manager.
- The endpoint is otherwise labeled as unreachable from a non-explicit fault condition for a call made to an unreachable endpoint.
