SIP Authentication Profile
To configure the SIP Authentication Profile:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the media-related
configurations.
ORACLE(configure)# session-router
Type
sip-authentication-profile and press Enter.
The system prompt changes to let you know that you can begin configuring
individual parameters.
ORACLE(session-router)# sip-authentication-profile ORACLE(sip-authentication-profile)#
You may now begin configuring the SIP Authentication Profile configuration element.
- name—Enter the name of this SIP authentication profile that will be referenced from a SIP registrar (or SIP interface).
- methods—Enter all the methods that should be authenticated. Enclose multiple methods in quotes and separated by commas.
- anonymous-methods—Enter the methods from anonymous users that require authentication. Enclose multiple methods in quotes and separated by commas.
- digest-realm—enter the digest realm sent in an authentication challenge (401/407) sent to a UA. This is required in ENUM/DNS deployments,.
- credential-retrieval-method—Enter ENUM-TXT.
- credential-retrieval-config—Enter the enum-config name used for retrieving authentication data.
- Type done when finished.
