Server-Capabilities AVP
The Server-Capabilities AVP is a group AVP including the Mandatory-Capability AVP and Optional-Capability AVP. The number of Mandatory-Capability and Optional-Capability AVPs is not limited in a Server-Capabilities AVP. The AVP symbol notation, format and reference follows:
3GPP 32.299 states the following symbols are used in the message format definitions:
- <AVP> indicates a mandatory AVP with a fixed position in the message.
- {AVP} indicates a mandatory AVP in the message.
- [AVP] indicates an optional AVP in the message.
- *AVP indicates that multiple occurrences of an AVP is possible.
Format definitions include:
- Server-Capabilities ::= <AVP header: 603 10415>
- *{Mandatory-Capability}
- *[Optional-Capability]
- *[Server-Name] (not supported in this release)
- *[AVP] (not supported in this release)
AVP reference, including column definition and AVP table follows:
- AVP Name
- AVP Number
- Reference where the AVP was defined
- Type of data format used to express the AVP's data
- If a grouped AVP, the names of the AVPs in the group
| AVP | Number | Reference | Type | Grouped |
| { Server-Capabilities } | 603 | Base | Grouped | Mandatory-Capability
Optional-Capability |
| { Mandatory-Capability } | 604 | Base | Unsigned32 | |
| [ Optional-Capability ] | 605 | Base | Unsigned32 |
