Manage Recordings
All user levels can be configured to view, edit, delete, download, and/or play recordings stored on the ISR (or other configured storage facility). However, a Tenant Administrator and Tenant User, if granted the appropriate permissions, can edit, play, download, and delete their own recordings only.
Recordings that display are dependent on the level of user currently logged into the ISR Dashboard.In addition to viewing, editing, playing, downloading, and deleting recordings, a user with Notes and Scoring permission can also specify notes for a recording, and specify a rate or score for a recording. A recording can be rated or scored from 1 star to 5 stars, with 5 stars being the best. For more information about assigning a score to a recording see Recording Details.
Access the Recordings from the Home page by clicking Recordings.
Each recording displays on the Recordings page with information about that recording.
Recordings Page
The following table describes each possible column on the Recordings page.
Column Heading | Description |
Start Time | Specifies the start date and time of the recording. This column is based on the User’s preferred time zone locale. |
From | Specifies the calling party. |
To | Specifies the called party. |
RSS Ingress Call ID | Specifies the call-id from the SIP headers of the initial INVITE. |
RSS Egress Call ID | Specifies the call-id from the SIP header of a secondary call leg. Only applicable for pass-through or Record & Save routes. |
Duration | Specifies the length of time, in seconds, of the recording. |
Session ID | Specifies the unique X-ISR-UCID for this recording. |
Playing a Recording
After a recording occurs on the ISR, it is saved as an audio, and optionally video, file so a user can review the details of the recording and playback the audio and video. Play a recording by first choosing it in search results or the default listing to bring up the Recording Details page, then clicking the Segment tab and the play button for that recorded Segment file.
The recording’s metadata is saved in the ISR database.The Recordings page displays all up-to-date recordings that meet the search parameters and access level restrictions of the user. Depending on the size of your storage device (Network Attached Storage (NAS), Storage Area Network (SAN)), older recordings may not be stored locally. However, this is transparent to the user viewing the recordings. Regardless of where the recordings are stored, all recordings display on the Recordings page.
Before playing recordings, make sure you have a media application that plays audio files with a .wav format. For more information about the software requirements and recommendations for playing recordings, see Requirements/Recommendations.
To play a recording:
Viewing and Editing Details of a Recording
The ISR Dashboard allows you to view and edit specific details and metadata of a recording if required. From a Recording’s Details page, you can:
- Play a recording.
- Assign custom data fields to a recording.
- Specify whether or not the recording is completed.
- Assign a length of time, in hours/minutes that the reviewer spent reviewing/transcribing the recording.
- Specify notes pertaining to the recording.
- Assign a rating to the recording.
- Create a category for which to place the recording.
- Transcribe the conversation that took place on the recording.
To play a recording from the details page:
Viewing Recording Details Recorder and RSS Information
- On the Recordings page, choose a recording and click Details. The Recording Details page displays.
- Click
Details.
- Recorder: Indicates the RSS that received the call session for the recording.
- RSS Ingress Call ID: Indicates the call-id received in the header of the initial SIP INVITE.
Notes and Scoring
You can include transaction notes and ratings for a recording by selecting Notes and Scoring from the Recordings page.
- Complete—Select
whether or not the call session represents a completed transaction for this
recording. For example, if a caller calls into a Technical Support Center for
problems with his PC, the call is recorded. If the problem was not resolved on
the initial call session, the reviewer can select No for the Complete
Transaction field, indicating that the problem was not resolved on this call.
Valid values are:
- No (default) - The transaction occuring during this recording is not yet complete.
- Yes - The transaction occurring during this recording is complete.
The Complete Transaction field must be enabled for editing. For more information about enabling this field for editing, see Recording, Editing Permissions. - Hours—Enter the length of time, in hours that the reviewer spent reviewing/transcribing the recording. Valid values are in decimal format using numeric characters. For example, 6.5, where 6 indicates the hours and .5 indicates 1/2 hour.
- Rating—Click on a
star to rate the recording. This is a score that you can assign to this
recording based on a level from 1 star to 5 stars, with 1 being the worst
rating, and 5 being the best rating. When all stars are blank, no rating is
assigned to the recording.
The Rating field must be enabled for editing. For more information about enabling this field for editing, see Recording, Editing Permissions. - Notes—Enter notes
pertaining to the current recording. Adding more than will fit in this box
displays scroll bars in the window that allow you to scroll through multiple
screens of the note.
The Notes field must be enabled for editing. For more information about enabling this field for editing, see "Recording Editing Permissions". Enabling the Notes field automatically enables the Transcription field. - Transcription—Enter the conversation that took place during the current recording. Adding more characters than will fit in this box displays scroll bars in the window that allow you to scroll through multiple screens of the transcription.
- Category—Enter a
category name to associate with the recording, and press <Tab>.
A category bubble displays in the Category field. This feature provides easy recording searches based on category rather than individual recordings.
To create additional categories to associate with the current recording, repeat Step 4.
- Click Update to save the details for the recording.
The above agent-focused fields are available through Dashboard and FACE at the overall session level, but not for individual Segments in the session. These fields are replaced with a much more flexible workflow using Custom Data in Segments and soon deprecated for overall session-level details as well.Recording Details File Location
The File Location section on the Recording Details page
provides information about storing a recording indefinitely.
Recording Details Custom Data
Specifies custom data values to associate with this recording. This information is specific to this recording
Create custom data fields via the Admin page's
Custom Data
Fields link. For more information on configuring Custom Data, see
"Custom Data".
To add or change detailed information about a recording, the user must have permission privileges for the Account’s route associated with the recording. To provide permission to add Custom Data Fields, see "Custom Data".Segment Details Configuration
Click the
Segment
# tab and the Segment details display.
Segment Recording Details Custom Data
Specifies custom data values to associate with this recording segment.
To add or change detailed information about a recording segment, the user must have permission privileges for the Account’s route associated with the recording. To provide permission to add Custom Data Fields, see "Custom Data".Segment Session Participant Metadata
You can view specific participant metadata for a segment, including extension metadata, about a recording by clicking Session Participant Metadata on the Recording Details page.
To view Session Participant Metadata:
Displaying DTMF Data in Segment Details: Routes
You can configure the ISR to display DTMF data within a call’s recording details for digits transmitted via RFC 2833 and SIP INFO. The Record DTMF parameter allows you to specify whether or not to display DTMF details on either a per-route or per-account basis.
To enable the ISR to display DTMF details for a particular route:
