Mapping NET-SNMP Configurations to Pre-5.2 ISR Monitor Tests
The following table maps the legacy, pre-5.2 Monitoring tests to the
current NET-SNMP configurations.
| Legacy Monitor Test Component Name | Current Test Coverage |
| <RSS_name> | Recorder process (including RSS host memory, disk, CPU, and network interfaces) |
| <RSS_name>'s API | API webserver process (including RSS host memory, disk, CPU, and network interfaces) |
| <Location_name_and_IP> - Disk | RSS host disk |
| <Location_name_and_IP> - Web Access | Recorded file webserver process (including RSS host memory, disk, CPU, and network interfaces) |
| ISR Dashboard | Dashboard webserver process (including RSS host memory, disk, CPU, and network interfaces) |
| ISR Index | Primary Index host MySQL database process (including RSS host memory, disk, CPU, and network interfaces) |
| ISR Secondary Index | Secondary Index host MySQL database process (including RSS host memory, disk, CPU, and network interfaces) |
