Recommended ISR SNMP Configurations
The following recommendations for each ISR component may be copied and added to an SNMPD configuration file as-is. However, the NET-SNMP suite is highly flexible and well-documented. For more information on the below configurations and to increase SNMP monitoring coverage of ISR and other Linux applications, see
Manpage of SNMPD.CONF - Net-SNMP.
You must restart SNMPD ($ sudo systemctl restart snmpd) for these changes to take effect.Recommended ISR RSS SNMP Configuration
For recommended RSS SNMP configurations, create a "/etc/snmp/snmpd.local.conf" file with the following configurations:
############################################################################### # ISR RSS configs # ISR read-only user rouser isrsnmp auth .1 # ISR app processes proc isrl.elf 1 1 proc converterl.elf 1 1 proc procmonl.elf proc java 1 1 # RSS host root disk remaining < 100MB disk / 100000 # cpu load load 12 14 14 # RSS process restarts logmatch recorderRestart /opt/isr/logs/recorder/recorder.log 120 VoIP Media Gateway.*starting logmatch converterRestart /opt/isr/logs/converter/converter.log 120 Converter Version.*
Recommended ISR Index SNMP Configuration
For recommended Index SNMP configurations, create a "/etc/snmp/snmpd.local.conf" file with the following configurations:
############################################################################### # ISR Index configs rouser isrsnmp auth .1 proc mysqld 1 1 disk / 100000 load 12 14 14
Recommended ISR Dashboard SNMP Configuration
For recommended Dashboard SNMP configurations, create a "/etc/snmp/snmpd.local.conf" file with the following configurations:
############################################################################### # ISR Dashboard configs rouser isrsnmp auth .1 proc ruby 1 1 disk / 10000 load 12 14 14
Recommended ISR FACE SNMP Configuration
For recommended FACE SNMP configurations, create a "/etc/snmp/snmpd.local.conf" file with the following configurations:
############################################################################### # ISR Dashboard configs rouser isrsnmp auth .1 proc java 1 1 disk / 10000 load 12 14 14
