Obtaining the NET-SNMP Configuration
Oracle Linux does not include the NET-SNMP suite by default. Oracle recommends adding the package on each
ISR host.
For more information on adding the yum tool's Oracle public repository on an ISR, see the "Oracle Public Yum Repository Configuration File" appendix in the Oracle Communications Interactive Session Recorder Installation Guide.Execute the following command on the
ISR host:
$ sudo yum install net-snmp
You must acquire and install the "net-snmp-utils" NET-SNMP package for the "snmpget" example commands. Execute the sudo yum install net-snmp-utils command to install the NET-SNMP utilities.
