Upgrade Caveats
The following items provide key information about upgrading with this software version.
Conversion Errors
An upgrade from 5.2 to 6.x likely results in conversion failures until each Location has been updated to properly reflect connections to the Converter using the Data Network. Log into the Dashboard and update each Location in the "Recording Converter" section by setting the "Converter IP Address" field to the Converter's data network IP address. You may confirm the Converter data IP in the "Converter Server Configurations" accordion of the corresponding RSS.
Previously Configured Locales
Any locales configured prior to upgrading to 6.3 will not work. You must delete existing locales and recreate them in 6.3. For more information on creating Locales, see the Administrator Guide.
