Hardware
The Interactive Session Recorder (ISR) components are distributed as applications running on Oracle Linux Releases 7.2 - 7.6, which abstracts the ISR application from the physical hardware. As such, ISR can be deployed on any hardware platforms that support Oracle Linux Releases 7.2 - 7.6. For a comprehensive list of the hardware platforms currently certified, see the Oracle Linux and Oracle VM Hardware Certification List (HCL).
ISR testing is predominantly done on Oracle Server X5-2 and Oracle Server X6-2 systems with the following resource configurations:
| Hardware Description | Quantity |
| Intel® Xeon® E5-2630 v3 8-core 2.4 GHz processor | 2 |
| One 16 GB DDR4-2133 DIMM | 8 |
| One 1.2 TB 10000 rpm 2.5-inch SAS-3 HDD with marlin bracket in RAID 10 configuration using 12Gb SAS RAID HBA | 4 |
RAID must be configured BEFORE performing the ISR component installation.Each of the ISR components must be installed on their own server/VM instance.
