Log Into Session Delivery Manager
Open your Web browser and connect to the
OCSDM server through your web browser using one of the following address formats (depending how you installed the
OCSDM web server):
HTTP (unsecured) session:
http://<OCSDM server IP address>:8080HTTPS (secured) session:
https://<OCSDM server IP address>:8443Note:
We recommend that during the installation, you select HTTPS as the system running mode so that your system can create secure connections over the network. -
In the login page, enter the appropriate user name and password and click
Login.
The OCSDM GUI appears.
