Customize Product Plugin Event Traps
The trap event setting allows you to override the default severities and customize them. Traps groups are provided for each product plugin that is installed in OCSDM. When you select a trap group the product plugin, SNMP trap (OID) list is provided. See your element manager product plugin documentation for the list of SNMP event traps and their definitions.
- Expand the Fault Manager slider and select Trap event setting.
- In the Select dialog box, select the AcmeSD trap group row from the Trap groups table and click OK.
- The following table describes the Session Delivery product event types and a description that references its respective trap. If you need to customize the severity level of this trap, see the Customize Alarm Trap Severity Levels section for more information.
