PreviousNextJavaScript must be enabled to correctly display this content
Upload a New Certificate
From
OCSDM, you can upload a
new X.509 certificate from your system to the
OCSDM trust store.
On the main menu,
select
Tools,
Certificates.
In the
Certificates dialog
box, click
Import.
In the
Upload
Certificate dialog box, complete the following fields:
Name field
The name of the X.509 certificate.
File field
The directory path of the certificate file on
your system. Alternately, click
Browse to navigate
to the certificate on your system.
The certificate appears in the
Certificates dialog
box with certificate name, issuer, start date, end date and serial number of
the certificate. The changes are propagated to any cluster members.
