Resolve Any Oracle Linux 7 Installation Dependencies
Resolve any of the following Oracle Linux 7.0 or later software library dependencies before you install OCSDM so that the OCSDM installation process runs properly. The following table describes the Oracle Linux 7 software library packages shared with Oracle Communications Session Delivery Manager.
Library Description
apr The Apache Portable Runtime (APR) supporting library is for the Apache web server that provides a set of application programming interfaces (APIs) that map to the underlying operating system (OS). The APR provides emulation where the OS does not support a particular function to make a program portable across different platforms.
apr-util The APR Utility Library (APR-Util) provides a predictable and consistent interface for underlying client library interfaces. This API assures predictable if not identical behavior regardless of which libraries are available on a given platform.
libxslt The package contains extensible style sheet language transformations (XSLT) libraries. These are useful for extending libxml2 libraries that are used to manipulate XML files to support XSLT files.
libaprutil The APR database binding library for the Apache web server.
libGL OpenGL-based programs must link with the libGL library that implements the GLX interface as well as the main OpenGL API entry points.
libX11 The X.Org stack, which provides an open source implementation of the X Window System for the C language X interface. See the X.Org Foundation for more information.
libXxf86vm X11 XFree86 video mode extension library provides an interface to the XFree86-VidModeExtension extension, which allows client applications to get and set video mode timings in extensive detail. It is used by the xvidtune program in particular.
alsa-lib Advanced Linux Sound Architecture (ALSA) library package used by programs (including ALSA Utilities ) requiring access to the ALSA sound interface.
If you are missing any shared software libraries in your Oracle Linux environment, run the "yum" program. Yum is the primary tool for getting, installing, deleting, querying, and managing Oracle Linux software packages from official software repositories, as well as other third-party repositories.
  1. Login to your Oracle Linux system on which OCSDM is to be installed as the root user.
  2. Install the Oracle Linux software on your linux system using the "yum" program. For example:
    yum install -y apr-util
