Set up Local Yum Repository
If your SDM server has no direct internet connection, you have two options to install dependencies: either set up a local yum repository on the SDM server or set up a local yum server on another machine on the same subnet as your SDM server.
- To set up a local yum repository on the SDM server, follow the instructions in Creating a Local Yum Repository Using an ISO Image.
- To set up a local yum server on the same subnet as your SDM server, follow the instructions in step 1 on the machine that will function as your yum server, and then follow the instructions in Setting up a Local Yum Server Using an ISO Image.
