Release 8.2.1 Features
The following table describes the Release 8.2.1 features for
Oracle Communications Session Delivery Manager (OCSDM).
| Feature | Description | Where Documented |
| SBC Bootloader Upgrade | Adds the ability to remotely upgrade the SBC bootloader image in addition to the SBC software image during software updates. |
| R226 Compliance | Eliminates the ability to view and edit both
Lawful intercept (LI) and SIPREC configuration elements when running in R226
mode.
Note: When R226 compliance is enabled, devices added with a LI encryption password can be managed by changing the device permissions via the Security Manager. |
| Lawful Intercept Config Options | Restricts the ability to view and edit LI configuration elements to the LIadmin user. |
| LDAP Filters Support | In addition to the existing mandatory LDAP
parameters, the OCSDM now supports the following additional LDAP attributes and
parameters:
| Audit Log Policy Enhancement | The audit log purging policy has been enhanced to always retain the last 48 hours of audit logs and cannot be configured to a lesser value. |
| Multiple Interface Support | OCSDM supports multiple interfaces as
follows:
| IPv6 Support | OCSDM supports IPv4 and IPv6 addresses for
the following different interfaces:
