Session Element Manager Plug-in Device Software Support
The following table describes device software support for the Oracle Communications Session Element Manager plug-in releases which have occurred since the introduction of OCSDM 8.0.
Refer to the "Plug-in Support Matrix" section for more information about what plugin is used with the product device releases mentioned below. All plugins inherit the support of the previous release, including the device releases mentioned in the "Historical Session Element Manager Device Software Support" section.| OCSEM Plug-in Name | Release Introduced | Latest Releases Supported |
SP Edge and Core |
3.0 |
Enterprise Edge and Core |
3.0 |
Enterprise Utilities |
3.0 |
For products/models supported in earlier OCSEM plug-ins, see the "Session Element Manager Plug-in Device Software Support" section in the "Historical Session Element Manager Device Software Support" appendix.
