Release 8.2 Features
The following table describes the Release 8.2 features for
Oracle Communications Session Delivery Manager.
| Feature | Description | Where Documented |
| Configure a Device Cluster Using a Bulk Spreadsheet | The OCSDM can provision a bulk device deployment using existing offline configurations and spreadsheets that contain required device details for the cluster. | The User Guide for the Service Provider Edge and Core Plug-in and User Guide for the Enterprise Edge and Core Plug-in's "Use an Offline Configuration for a Device Cluster" chapter includes a new section, "Configure a Device Cluster Using a Bulk Spreadsheet". |
| Manage Route Sets Using REST | A REST user can create and modify route sets, add or remove routes to a route set, and update all or some SBC devices with a specific route set. |
The REST API documentation is located at https://docs.oracle.com/cd/F18700_01/REST/. The REST API documentation for managing route sets is located at https://docs.oracle.com/cd/F18700_01/REST/api-route-sets-management.html. |
| Acme Packet 3900 Service Provider Edge and Core Plug-in Support | The Service Provider Edge and Core Plug-in now supports the Acme Packet 3900 platform. | The "Device Platform Support For Oracle Communications Session Element Manager Plug-ins" table in the Release Notes has been updated with this information. |
