User Group Privileges
In
Oracle Communications Session
Delivery Manager, user group privileges can be applied to user groups
that you add to allow or deny all users within this user group the ability to
perform certain operations. This includes items intended for use with separate
application products. For the default
LIAdministrators,
administrators,
provisioners, and
monitor user groups,
only device group privileges can be changed.
Upon installation of OCSDM, if R226 compliance is enabled, the Lawful Intercept and SIPREC features and their attributes are hidden from view and are not configurable.User group privileges that are assigned to either the administrators or LIAdministrators user groups inherit most of the same access privileges. However, users assigned to the LIAdministrators user group have full configuration privileges to manage the Configure LI element (Lawful Intercept) in the Device configuration subfolder within the Configuration folder in the Configuration tab. Users assigned to administrators, provisioners and monitors default user groups do not have privileges to configure the Configure LI element.
If Lawful Intercept (LI) is enabled on a device that OCSDM manages, LI configuration values become encrypted on this device and OCSDM.
