Configure the BI Publisher Security Model
Open your web
			 browser and log into BI Publisher with the following URL:
http://<hostname>:9502/xmlpserver
- In the Oracle BI Publisher Enterprise login page, enter weblogic in the Username field.
- Enter the password for the Weblogic user that you set in the Define New Domain window in the Oracle Business Intelligence 12c Configuration Assistant. Refer to Start the Business Intelligence Configuration Assistant 12c section for more information.
- In the top right corner of the page, click Administration.
- In the Administration page, under the Security Center heading, click Security Configuration.
- Scroll down the page to the Authorization heading and select BI Publisher Security from the Security Model drop-down list.
- Enter the administrator password in the New Password field.
Scroll to the top
			 of the page, and in the top right-corner, click
			 Apply.
The settings are saved successfully, but do not take effect until the application is restarted.
- Scroll to the top of the page, and in the top right-corner, click Sign Out.
Restart the
			 WebLogic server. Refer to the
			 Start or Stop the WebLogic Server for 12c
Note: After restarting the WebLogic server, the weblogic account is disabled. Administrative actions must be performed with the administrator account.
Login to the
			 WebLogic server, complete the following fields:
Username field Enter administrator in this field. Password field Enter the new password that you configured in step 7.
- Click Sign In to enter a new session.
